didiers
SMPS en audio !
le Sam 29 Oct 2016 - 16:29
Hello la communauté des passionnés, spécialistes et autres amateurs de choses bien faites Wink
Ceci est mon premier post en tant que nouveau venu sur cet agréable forum que j'ai découvert il y a quelques jours avec un réel plaisir Smile
En guise de première contribution, voici une réponse à une question posée sur un forum d'électronique que je trouve intéressante à partager :
La question est " Un circuit audio peut-il être alimenté par une alimentation à découpage (SMPS) ? "
Voici la réponse :
Let me give you a little background on myself... I've been working professionally in the audio industry for more than 14 years. I've designed circuits for most of the major pro-audio companies, one audiophile company, and several consumer audio companies. The point is, I've been around and know a lot about how audio is done!
SMPS can and are used for audio circuits! I've used them from sensitive microphone preamps to huge power amplifiers. In fact, for the larger power amplifiers they are mandatory. Once an amplifier gets over a couple of hundred watts then the power supply needs to be super efficient. Imagine the heat produced by a 1000 watt amp if it's power supply was only 50% efficient!
But even on a smaller scale, the efficiency of a SMPS often makes a lot of sense. If the analog circuitry is properly designed then the noise from the power supply gets rejected by the analog circuitry and doesn't impact the audio noise (very much).
For those super-noise-sensitive applications you can do a hybrid approach. Let's say that you have an ADC that requires +5v. You can use a SMPS to generate +6v, then a super-low-noise linear regulator to bring that down to +5v. You get most of the benefit of the SMPS, but the low-noise of the linear regulator. It is not as efficient as just a SMPS, but those are the trade-offs.
But one thing to keep in mind... A SMPS for audio applications needs to be designed with audio in mind. Of course you'll need better filtering on the output. But you will also need to keep other details in mind. For example, at very low current the SMPS might go into something called "burst mode" or "discontinuous mode". Normally a SMPS will switch at a fixed frequency, but in one of these modes the switching will become somewhat erratic. That erratic behavior might push the output noise into the audio frequency band where it becomes more difficult to filter out. Even if the SMPS is normally switching at 1 MHz, when in one of these modes you could get 10 KHz noise. Controlling how this happens depends on the design of the chip that the power supply uses. In some cases, you can't control it. In that case you have no choice but to use a different chip or use a hybrid approach.
Some people advocate using only linear power supplies for audio. While linear supplies are less noisy, they have lots of other issues. Heat, efficiency, and weight being the biggest ones. In my opinion, most of the people who preach linear supplies only are either misinformed or lazy. Misinformed because they don't know how to handle switching supplies or lazy because they don't care to learn how to design robust circuits. I've designed enough audio gear with SMPS to prove that it can be done without too much pain.
Source : h**p://electronics.stackexchange.com/questions/36674/can-an-audio-circuit-be-powered-by-a-switched-mode-power-supply
Salutation à tous, et excellente soirée Wink
Didier
legarem
Re: SMPS en audio !
le Dim 30 Oct 2016 - 9:58
Une chose est certaine c'est que plusieurs SMPS ne sont pas dignes d'être utilisés en audio. J'ai plusieurs fois modifié des mac minis en mettant une alimentation linéaire de qualité et c'est la meilleure transformation qu'on peut faire si on veut du bon son.
